“Unable to activate eSIM” after scanned the QR code
Wuhoo
I had initially downloaded the Public Mobile app, and followed its steps to activate the eSIM. Then my phone showed it can’t activate. Then I went on my email and scanned the QR code, it then popped “Unable to Activate eSIM you can try again, or contact your carrier for assistance.”
I went to my “Setting”-> “Cellular”, I can see the eSIM is there, and I had “turn on this line”, but I still couldn’t receive any text messages, unless I insert my physical SIM card (which has the same number with eSIM I applied)
I went through the community and tried all methods, nothing worked and still can’t receive text messages solely with eSIM. Please help me.
btw, I had received an text message from public mobile right after I failed my initial activation when entering the newly downloaded app. By that time I still have my physical SIM card inserted so that’s why I can receive this message. It says “Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided.”
2 REPLIES 2
@Wuhoo
For the eSIM,  make sure the PM eSIM is set as Primary on "Cellular Plan Label" after "Turn on This Line" is toggled on
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
@Wuhoo  Submit ticket with support here
send  a  private message   To CS_Agents
