01-07-2025
03:08 PM
01-07-2025
08:26 PM
computergeek541
Hi,
Signed up, got a sim, downloaded the app and tried to activate. I get to a point where it asks for a confirmation code sent to my new number in order to proceed but no text comes in. Please help!
01-07-2025 04:27 PM
Just reboot your phone by powering off then back on and see if you get the 2FA code or you have the option to send the 2FA code to your registered email.
01-07-2025 03:12 PM
Wow - thanks for the quick reply. No, I'm not even porting yet. Just trying to use a new Public assigned number.
01-07-2025 03:11 PM
hi @LeanneG
if you requested porting, the 2FA code would have sent to your old carrier sim card. Check there
if you still cannot get the code, ask PM support agent. You can submit by direct message:
