01-07-2025
02:09 PM
01-07-2025
08:29 PM
computergeek541
My phone is always buffering on Facebook videos when I’m on public mobile but not when I switch to wifi. Does anyone know why this is happening. It did not do this when I switched to Public Mobile 2 months ago.
01-07-2025 04:30 PM
Do you have a VPN on your phone? If you do, just disable it and see if that helps.
I have this issue when I have the VPN enable.
01-07-2025 02:19 PM
hi @Beatty
87Mbps vs 110 won't make much different, it won't jump from good to buffer, Especially that Facebook videos are not huge video file. it could be a problem on FB side
but if you can also reboot the phone, clear app cache if Android
01-07-2025 02:18 PM
@Beatty Do you have a data/battery saver setting on?
01-07-2025 02:15 PM
Download speed is 87mbps was 110 this morning.
01-07-2025 02:11 PM
@Beatty , how is the signal strength in your locale? Install a speed test app and check download speeds.
