01-04-2022 09:03 AM - edited 01-06-2022 04:06 AM
We are in the US now and my phone does not allow me to text or talk even though I changed my plan from 40.00 to 50.00 and have 2 add-ons. I want to be able to talk, text from USA to Canada and have data on my phone while I am in the US please help
01-04-2022 12:49 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
make sure enable roaming on,
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, to do it for you...
01-04-2022 10:01 AM
Reset network settings already and got the text welcoming me and said I needed an add on so did that first night I was in USA
01-04-2022 09:55 AM
Did you get the welcome to USA Public mobile text?
Some other things to try as your wait for CSA help:
Network reset of phone
Enable international roaming on some phones in settings.
01-04-2022 09:54 AM
One line saying talk , another saying text
01-04-2022 09:54 AM
@Icemanleith : Do you have more than one of each kind of add-on? Or do you just show one line saying talk and one line saying text?
01-04-2022 09:53 AM - edited 01-04-2022 09:54 AM
@Icemanleith wrote:Yes. They are showing there
@Icemanleith - Have you been able to use Roaming addons before?
Do you have the "Data ROAMING" option selected (turned ON) on your device?
If yes to above, do you have, or are you travelling with someone else you can try your SIM card into to see if you have services then?
Not sure if this will work while in the USA, but this is sometimes recommended while in Canada, so thought I would throw this out there...
What happens if you manually change your Mobile Networks under your Connections settings to 3G / WCDMA ONLY?
01-04-2022 09:48 AM
Thanks. Sent a private message
01-04-2022 09:39 AM
01-04-2022 09:39 AM
@Icemanleith is this the first time you buy the US roaming? I meant not like your bought once already for this trip and now 10 days later you are buying a 2nd round, right?
while we are trying to help, maybe open a ticket with PM support as well.
- For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
01-04-2022 09:37 AM
@Icemanleith wrote:I just checked my add ons and I have roaming USA unlimited talk 10 days and also roaming USA unlimited text 10 days
@Icemanleith - do you mean you see these listed under "Plan Details" area?
This is where they should be showing.
01-04-2022 09:32 AM
01-04-2022 09:25 AM
Yes. Manually connected to A TAnd T, also T mobile
01-04-2022 09:23 AM
@Icemanleith you tried connected to both ATT and TMobile?
01-04-2022 09:21 AM
Yes. Rebooted a number of times and manually connected as well. Someone suggested to turn airplane mode on and off. Did that as well.
01-04-2022 09:16 AM - edited 01-04-2022 09:17 AM
@Icemanleith wrote:I added talk and text in USA and added funds and then confirmed that I wanted the add on. When I go to my plan and add ons, they show up
@Icemanleith Have you tried rebooting the phone? How about manually try to connect to AT&T or T Mobile?
01-04-2022 09:15 AM
01-04-2022 09:09 AM
@Icemanleith wrote:Already added a roaming plan
@Icemanleith See my edit above....
01-04-2022 09:09 AM
@Icemanleith you will need US roaming Add on to have your phone works in US. you said you have 2 Addons, which 2?
a reminder, buying add on is a 2 steps proceess, 1. Load Fund. 2. Actual buying. Any chance you did just step 1?
if you really got your US roaming add on, try to connect to wither T Mobile or AT&T and see which one connect better
01-04-2022 09:08 AM
01-04-2022 09:07 AM - edited 01-04-2022 09:13 AM
@Icemanleith wrote:We are in the US now and my phone does not allow me to text or talk even though I changed my plan from 40.00 to 50.00 and have 2 add-ons. I want to be able to talk, text from USA to Canada and have data on my phone while I am in the US please help
@Icemanleith The plan you subscribed to that includes US calling only works if you are calling the USA FROM Canada. Is one of your add ons the US Roaming? If not you need to add funds to your account then go in an purchase the applicable US roaming package which is valid for 10 days.
Edit: If you have purchased a USA roaming package, make sure that the funds are not showing in your account as the 2 step non intuitive add on purchasing process can be confusing. As mentioned above you need to add the funds then go and purchase it. If you are showing the US roaming add on in your account try rebooting your phone.
