Voice mail while in US
michellebisson
I am in the US on travel and my plan does not include the US.  How do I check my voice messages?
@hTideGnow wrote:
if your plan does not include US roaming or you did not buy US roaming addon, you cannot use your phone to check voicemail
however, you can still check it.  Just download VoIP app like TextNow and it will give you another 10 digits phone number.  You can then use the app to call yourself, click # when you hear the voicemail greetings and enter PIN and check voicemail this way
The above isn't correct information.  Telus voicemail system don't use # for that. # won't work.
Grinch
To directly answer your question.
From a land line or another cell phone that works in the USA.
How To Access Your Voicemail From Another Phone
  1. Call your phone number
  2. When you hear your voicemail greeting, press the star key (*) to interrupt it
  3. Enter your voicemail password when prompted
  4. Follow the voice prompts to listen to your messages
hi @michellebisson
