USA/ Canada Plan, Data not working in USA
04-19-2024
10:16 PM
04-20-2024
02:15 AM
computergeek541
I’m in Florida right now and it’s really spotty. Even though it will say I have full bars of data, nothing will load, iMessages won’t send. Sometimes it will work, sometimes it won’t. Any fixes for this? I have roaming enabled. I have the 60gb/month 5g unlimited everything else USA/Canada plan.
Service
04-20-2024 11:12 AM
You’re welcome! I’m happy to have helped. 😊
04-20-2024 09:53 AM
I’m having the exact same issue as the first prompt in this thread. This comment solved the issues for me! Thank you!
04-19-2024 10:52 PM
Change your network settings to 4G preferred. AT&T 5G won't work, and is likely what's causing you problems. And make sure you're connected to either T-Mobile or AT&T (not Verizon). And of course make sure data roaming is on.
04-19-2024 10:40 PM
make sure to disable Wifi Assist in the settings on your phone.
04-19-2024 10:24 PM - edited 04-20-2024 12:42 PM
Ensure data roaming is turned on. If your phone is 5G, change it to LTE or 4G. Turn off auto network selection and manually choose T-Mobile or AT&T. They are the only PM roaming providers. (Verizon won’t work.) If you find you can connect to T-Mobile using LTE/4G, you can then try changing your phone back to 5G. (Others in the Community have stated that AT&T won’t work with 5G.)
04-19-2024 10:24 PM
Talk and sms message work fine… data is the main issue. Sometimes it will work, sometimes it won’t. My phone has volte
04-19-2024 10:23 PM
HI @benhedge
it's a bit hard to connect 5G in US for some reason. Try using 4G or LTE
and try manually connect to T-Mobile and AT&T , test both networks
04-19-2024 10:20 PM
your email should be working as expected...right ? Talk may be an issue if you don't have a volte enabled cellphone. If that's the case, try manually selecting 2G for talk and use only T-Mobile. Without a volte enabled phone you're limited to 2G for talk...which will be less than great.
