03-30-2025 06:13 PM
I recently ported my phone from another carrier in Canada then took a vacation to Mexico where my mobile data is not working. Does anybody have any solutions?
03-30-2025 06:29 PM - edited 03-30-2025 06:29 PM
Try manually selecting the different Mexican networks and restarting (make sure your roaming is turned on). That has worked for some others. If not, message a customer service agent as previously suggested. Good luck.
03-30-2025 06:26 PM
once you're sure Roaming Data is enabled, you can try using the best of either AT&T, Telcel or Movistar. Once of those should work for you.
03-30-2025 06:23 PM
Hey @GirlB
One of the other customers had issues too. Here's the thread that helped him and got his data working again.
03-30-2025 06:21 PM - edited 03-30-2025 06:21 PM
Couple tricks to try: ensure data roaming is on, reset your phone networks and manually choose whichever service provider shows up. Try anyone that works. Restart phone.
