Need help Trying to activate subscription
Ultra_hdr
I am trying to activate a new subscription,  I got a new physical Sim, I got to the step where I can choose a number once it activates I get an error message to contact support ...  impossible to get any help
funpig1
@Ultra_hdr
With that error message, there's nothing that you can do on your end except to send a message to the customer service agent to fix. Good luck.
Ultra_hdr
slusagm
must be some system problem this weekend, many got the same error
PM complete the activation for you and you need to submit a ticket.    Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
