06-18-2026 05:13 PM
I need help.
Tickets are not working.
Can't receive calls or send texts.
Data ok, reception crap.
Ported my number from bell 20 hours ago!!
Wtf
06-18-2026 05:14 PM
make sure you removed the Bell sim card , or disable Bell esim
Enable PM sim and set it with Label Primary. Then, Reset Network Settings once more time after a device reboot
If issue persists, you will have to engage PM CS support and they will need to re-provision your account. Private message CS Agent at: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
