06-22-2026 10:10 PM
Hi, my data stopped working a few days ago.
I’ve tried restarting etc and nothing works.
please help!
06-22-2026 11:12 PM
Thanks for your advice, checked outage - was ok - and performed reset, still not working, will contact support 🙏
06-22-2026 10:16 PM - edited 06-22-2026 10:18 PM
check Telus outage site to confirm any local outage:
https://www.telus.com/en/on/outages
Also, preform a Reset network settings after a device reboot
If you are using iPhone, make sure you update the Carrier Profile
if issues persists, ask PM CS agent to reprovision your sim/account. Please open ticket with PM support:
06-22-2026 10:14 PM
@Leonie59 wrote:Hi, my data stopped working a few days ago.
I’ve tried restarting etc and nothing works.please help!
Hello @Leonie59
Could you be at your data limit already? Not all plans have unlimited data. You may wish to log into your account and double check.
Try turning Airplane mode on. Turn off the phone, wait a full 5 minutes and turn the phone back on and turn off Airplane mode. This will reconnect you to the network.
Also, check your phone to make sure it's VoLTE enabled.
To confirm if your phone will work with Public Mobile, please see this link. At the bottom of the page, you can insert your IMEI number and the system will advise you if it will work with Public Mobile.
https://www.publicmobile.ca/en/get-help/articles/volte
Use Public Mobile's VoLTE checker as a guide only, as results are not always 100% accurate.
If you still need help, contact customer service.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
06-22-2026 10:14 PM
Try a network reset… let us know the result.
