US roaming how much
CathyD1
How much does YS roaming cost
shimdog
You should be able to find this information with the rest of the plan costs. Look under add-ons. https://www.publicmobile.ca/en/on/plans#plans-start
@CathyD1  US roaming is not cheap and a bit inconvenient for long trip as they only offer 10 days package and need to renew if you are there longer than that.
Consider to use local US data SIM , it's cheaper and offer more data.
t_p
@CathyD1
You have the full list here:
Plans (publicmobile.ca) > Add-ons > US Roaming (10 day packages)
Don't forget they are good for 24x10=240 hours and the counter starts right away after purchase.
Meow
Purchasing add-ons is two step process: add funds and then go back to purchase correct add-on. Make sure to purchase the add-on as close to trip date as the clock starts immediately upon buying and is limited for 10 day x 24 hour period.
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
@CathyD1
250MB = $10
500MB = $15
1GB = $20
and Purchase when you visit to USA not now,
sign in to Self-Serve, to review your account,
How To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
  5. after you Add-on you have to do Rebooting your phone
    what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
