08-19-2023
12:31 PM
08-19-2023
12:41 PM
computergeek541
08-19-2023 03:52 PM
That’s okay! I’m just happy that it got their service working again. That’s most important
08-19-2023 02:01 PM
Happy to hear it’s working for you! Enjoy your time in the US!
08-19-2023 01:59 PM
yes, supposed to be both T-Mobile and AT&T . But AT&T has not been working for more than a year. Just last week , someone said AT&T working again. I just want to confirm.
08-19-2023 01:54 PM - edited 08-19-2023 01:55 PM
hi @mmikhaila in the end , you are using TMobile?
08-19-2023 01:52 PM
As a follow up to this as well I forced my phone to the LTE network and it worked better than the 5G network. My two other people with me who have the same plan also had to switch to the LTE network.
08-19-2023 01:41 PM
Ok thanks I found where you were talking about and it was off I’ll work from there and try restarting.
08-19-2023 01:37 PM
@mmikhaila wrote:
I have a subscription that is supposed to include US data but I am in the US and I can text and call but my data is not working. eSim card on an iPhone 13. I have already tried turning roaming on but that option is not available.
HI @mmikhaila
you need to find an Apple store around, there is no reason that option not available ..
08-19-2023 01:34 PM
thanks @MetaMorpheusMob
you have roaming data here?
From the Home screen, tap Settings. Tap Cellular. Tap Cellular Data Options. Tap or slide the Data Roaming switch to ON
08-19-2023 01:29 PM
hi @mmikhaila what phone do you have?
08-19-2023 01:28 PM - edited 08-19-2023 01:29 PM
Are you going into the deeper menu to find the data roaming toggle? If you go to Settings, Cellular, then click on your phone number in the SIMs section it should bring you to further menu’s and Data Roaming can be found there on the lower half of the screen.
Or is the option not clickable for you?
08-19-2023 01:28 PM
HI @mmikhaila
what is roaming not available? is the option greyed out? you need it enabled to use roaming data
08-19-2023 01:16 PM
Michigan
08-19-2023 01:16 PM
08-19-2023 01:12 PM
I purchased a Canada US plan.
08-19-2023 01:09 PM
in iPhone Settings / Cellular / Cellular Data Options / ..make certain Roaming On is showing.
Do you have the Canada & US plan or did you buy a US Roaming add-on ?
08-19-2023 12:46 PM
Editing my comment to reflect this. Thanks 🙂
08-19-2023 12:45 PM - edited 08-19-2023 12:57 PM
I tried that and it did not work. Do you have any other suggestions?
08-19-2023 12:40 PM
@JRod wrote:Hello @mmikhaila
If you go into network selection, turn off automatic and try manually selecting Public Mobile or T-Mobile then reboot.
When it the U.S., there wouldn't be any Public Mobile network to select.
08-19-2023 12:32 PM - edited 08-19-2023 12:46 PM
Hello @mmikhaila
If you go into network selection, turn off automatic and try manually selecting T-Mobile then reboot.
08-19-2023 12:32 PM
@mmikhaila wrote:
- I have a subscription that is supposed to include US data but I am in the US and I can text and call but my data is not working. I am using an eSim card on an iPhone 13. I have already tried turning roaming on but that option is not available. I have toggle to Airplane mode and back again and I have tried restarting my phone.
My suggestion woudl be to try manually connecting to the T-Mobile network. The AT&T network is known to cause issues for Public Mobile cusotmers.
