US Roaming
06-02-2023
10:20 AM
06-04-2023
01:15 AM
Dunkman
06-02-2023 10:42 AM
06-02-2023 10:28 AM
Do you see the roaming add-ons in your list of add-ons? Did points get deducted off your points balance?
06-02-2023 10:27 AM - edited 06-02-2023 10:28 AM
So here in the community, if you want some help, details are key. Have you used the search bar to see what others have done to fix this same issue?
What have you done or checked so far?
Is data roaming enabled?
Connected to T Mobile?
06-02-2023 10:25 AM
Might be a silly question, but have you enabled data roaming on your phone?
06-02-2023 10:24 AM
@Bsb Reboot the phone and make sure you connected to T mobile
