2 hours ago - last edited 2 hours ago
Hi what’s the difference between these two plans
one i got during the promo the other is a dollar more but does it include talk and text in the states (call from the states, text sms , etc?)
Current plan i got notifications about addon so i assume that’s not included my current plan ONLY DATA
the fine print shares the same so the “ canada AND US” equals to “ canada-US wide” which is my current plan
sounds like public mobile is using a twist on words to trick you into thinking you got call and text in the states for free
27 seconds ago
so i need to be voLTE in order to do sms and call? text/call? through whatever service provider im connecting to? or will i not get charged because voLTE is calling through data, not the same … using my data in US not the calling
7m ago
Both are full Canada/US plans, including data, text, and calling. Unless you need the 100 long distance minutes, don't pay $1 more to get slower 4G service (vs 5G on your current plan) for the same amount of data.
And yes, you can make phone calls in the US with your current plan, assuming your have a VoLTE device.
2 hours ago
HI @serg3
the T&C is a one template for all plans, so not all terms apply to your plan
but overall, you can use data in US for internet, iMessgae, facetime, streaming, no need to avoid.
And PM is prepaid provider, so, you won't get charged for things you didn't "buy" ahead
2 hours ago
@serg3 wrote:i see
but the terms and conditions has me suspicious
so i’ve been avoiding using phone in usa aside from data and imessage facetime etc
There is one very important fact you seem to be forgetting. Public Mobile is a PRE PAID service. Meaning you pre pay for what you want. Since you have a Canada US plan, you've paid to use your phone in the US. You will NEVER be charged extra for any reason. No roaming fees, no going over data limits.... NOTHING! 🙂
I've had the Canada/US plans before with Public Mobile and I used it like I was at home with no issues.
2 hours ago
i see
Oh. I see. The difference is you get 100 China calling minutes for $1 more along with other LD. They are both Canada US plans. And one plan is 4G and the other is 5G.
HI @serg3
both are Canada-US Plans,
the $35 has a LD included for calling those couple countries, but only 4G speed (So, your old $34 plan as 5G)
If you don't need to call those countries, $34 plan is the better one
2 hours ago
i see one plan say use the “-“ while other says “and”,
the “-“ one says it needs to be calls/texts made from canada to be
but new an for 35 says it’s “and” but still uses same terms and conditions as “-“ plan
2 hours ago
sorry
thought i attached the photos, updated
and replied elsewhere
2 hours ago
sorry
it doesn’t, my plan says i need to make calls from canada to states to be fine, plus i get texts on adding minutes when i enter
2 hours ago
WHICH two plans you are talking about?????
Every USA/Canada plan have everything unlimited. Only difference is data.
2 hours ago
HI @serg3
i would guess yours is a full Canada-US plan.
but can you show us what plan you have now? Check your My Account -> Subscription & Add-on page and it should show you the plan details
and show us the plan you said $1 difference
Sometimes, PM offer 2 same plans but with slight price difference
2 hours ago
Hey @serg3
Which plans are you speaking of?
Any plans that's Canada/US basically means you can use Public Mobile in both countries with no extra fees. Basically use your phone like you were at home.
