U.S. 5G Roaming with AT&T does work
06-13-2024
11:30 AM
06-13-2024
03:06 PM
computergeek541
For information purposes:
I have a Canada-US plan and I am currently driving through Northern Michigan. I have an iPhone 12 and I have my network selection set to Automatic. I want to confirm that 5G works with both AT&T and T-Mobile. Verizon was recently added as a PM roaming partner but I can’t connect to it with 5G or 4G.
Service
06-16-2024 02:38 PM - edited 06-16-2024 04:38 PM
@hTideGnow In Bellingham right now and AT&T 5G is working! For the moment anyway. Speed not great, but that's likely because I'm in Costco.
I wasn't able to even connect to Verizon, but I can try again in a different area.
Edit: No go with Verizon, but AT&T 5G continued to work, and was the default connection during my couple hour trip.
06-13-2024 03:45 PM
thanks for testing @colleeno
and @DennyCrane , let us know if you have luck with Verizon.
06-13-2024 02:45 PM
@DennyCrane Verizon is mentioned on the help page.
https://www.publicmobile.ca/en/on/get-help/articles/roaming-add-ons
06-13-2024 01:51 PM
@colleeno 🤔, I haven't seen that, and it would appear from your experience to not be true. I'll test it myself this weekend too, but to my knowledge Verizon still isn't a Public Mobile roaming partner.
06-13-2024 01:50 PM - edited 06-13-2024 01:51 PM
@DennyCrane It’s something new I think. I have seen it mentioned recently in this Community. @hTideGnow said it can be found on the Help page.
06-13-2024 01:47 PM
@colleeno What makes you think Verizon is a roaming partner then? I know they are on Telus, but had not been on Public Mobile. Was something communicated about this?
06-13-2024 01:44 PM
@hTideGnow I did try to connect to Verizon without success.
06-13-2024 01:23 PM
Thank you. I'm going down this weekend so I'll do some testing too.
06-13-2024 12:19 PM
Nice to see the 5G works on both AT&T and T-Mobile. I wonder if the addition of Verizon is still work in progress and the help article got ahead of its skiis.
06-13-2024 11:47 AM
Great, thanks for info!
06-13-2024 11:40 AM
thanks @colleeno for confirming.
can you try Verizon? I saw people talked about PM added Verizon, and the Help page also showing that
