a week ago
Thursday
I can't definitively confirm your identity as I cannot access any personal information you haven't shared during this conversation. However, I can help you with some methods commonly used for identity confirmation depending on the context:-
Here are some ways identity confirmation is done online:-
In the physical world, some common methods of identity confirmation include:-
a week ago
Thank you everybody!
a week ago
If the old SIM still works then porting was not completed. See if the text came in confirming are porting over to PM with YES.
If it passed the 90 minute window, contact an agent to have your old carrier resend the text so you can confirm.
a week ago
hi @ATanya
sound like the number not ported yet. But check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
a week ago
The number is transferred from a different mobile carrier. I can make outbound calls, but I can't receive any calls and messages.
a week ago
Yes, the number is from a different mobile carrier. I didn't respond "yes", because the SIM was exchanged. I've checked now the previous line is still working. To repeat the request of transfer from the old carrier account do I have to call them or is it possible to send the request online again?
a week ago
hi @ATanya is that mew account with number to port in or you got new number??
and can you make outbound calls with your PM sim card??
a week ago
Did you port your number from a different mobile carrier? If you did port over, did you respond "yes" to your old carrier port request confirmation text? Do you still have your old carrier SIM card? Try re-insert to see if your old carrier account is still working.
