03-06-2025 12:38 PM
Hello,
the plan said it would work in Mexico, and it was working and then it stopped working.
how do I speak with customer service
03-06-2025 02:04 PM - edited 03-06-2025 02:08 PM
I'm currently in Mx and my talk/text/data is working as expected. My cell usually connects to AT&T, but could connect to Telcel or Movistar as well. Try moving around to a different location maybe. Try rebooting see if that helps.
added...what feature isn't working for you ? Talk/text or data...or all of 'em not working ?
03-06-2025 12:48 PM
hi @Leigh1234
it is just a local network problem. Change the network mode to 4G or LTE
then manually select AT&T and Telcel. One of the two should work
