03-06-2025 01:35 PM
Hi there,
I've tried submitting a support ticket multiple times now and keep getting an error message even with all of the required iunfo seemingly submitted.
I Just signed up with you folks and the number transfer never worked. I restarted my phone multiple times and waited over 24 hours but the new esim only ever had the temp number.
I got a message from Virgin, my old provider, indicating a number transfer had been received. I also got a message from Public Mobile that asked me to say YES to confirm, and I did this.
I deleted the esim thinking I could download it again, but I guess I need a new one now.
Not sure what to do here and I've been out a phone for a couple days now. Pretty frustrating.
03-06-2025 01:47 PM
Thanks for the direct message link, that worked. Appreciate it.
03-06-2025 01:47 PM
ok, I'll give this another shot. I keep getting error messages when I try to submit the ticket though.
03-06-2025 01:38 PM
hi @Tion
from what you said, it is not a porting problem but a program with account or sim setup. You need to work with PM support. Unfortunately , there is no number to call for live support, you need to submit ticket
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
https://productioncommunity.publicmobile.ca/t5/notes/privatenotespag
03-06-2025 01:36 PM
Would be great if I could talk to a live agent, but doesn't seem to be an option.
