New subscription
Bilbo123
Transfer didn't work...was told to contact Support.  There is no support...does Public Mobile really have no agents to help get new customers working?
1 REPLY 1
TheSterlinger
@Bilbo123  all support from customer service agents are through messages.
You can contact them through the following link.
If you encounter issues then you can use the next link below.
An agent will usually reply with 30 minutes to 2 hours.
