Two step verification on log in.
bostrosky
When I log into my account I tick trusted device. On my next log in I am asked for a two step verification code again. Is this a system glitch?   Thx
9 REPLIES 9
bostrosky
Thx for reply, using browser.
HI@bostrosky   are you using iPhone app? iPhone app has that problem, known issue
and if you are using browser, check if there is a setting for clear cache when exit
bostrosky
Thx for the reply. I haven’t tried on my Desktop but on my iPhone and iPad no luck ticking trusted device. Note: I am not using the App, I use the website.
Meow
I declared my COMPUTER as trusted device (browser) and I am never asked for 2FA.
Do not know how it works on phone as I never use it to manage PM.
bostrosky
Yes.
@bostrosky  In my case none , but on computer you may have better success . It seems to be hit or miss for customers
@bostrosky - are you able to log into My Account alright? If so, then EverSafe is just doing its thing.
bostrosky
Thx for the reply. So what purpose does ticking trusted device serve?
Thx
@bostrosky  No it’s just the new way , signing in works much like a bank app
