08-08-2023 08:20 AM
How do I change it so I no longer need to get a code text to my phone just to log into my account? I keep selecting “trustee device” but it still asks me each time
08-08-2023 05:58 PM
It never remembers me either, I've just come to accept the 'Remember this Device' only remembers for a few hours before you have to log back in and get the 2FA Code again.
Just the way it is now, I miss the days of being able to disable 2FA all together.. it is still an option to turn off in settings with Koodo Pre-Paid but not here anymore..
08-08-2023 12:37 PM
Hmmm, It doesn’t on my iPhone or computer.
08-08-2023 10:42 AM
@BKNS27 Autofill works for my username and password on both the app (Android) and my computer.
08-08-2023 10:40 AM - edited 08-08-2023 10:41 AM
Trusted Device didn't work very well for me in the beginning, but lately it has been very good. Rarely do I need to go through 2FA on my trusted Device anymore. I'm on Android, not sure if that makes a difference.
If you set your browser to automatically clear cache and cookies on exit, that could be the issue.
08-08-2023 10:12 AM - edited 08-08-2023 10:41 AM
You may have to login to your account a few times by clicking on Trusted Device while you are connected to home WiFi.
But you need to confirm every time if you are on public WiFi or data or using Face ID.
BTW, autofill will not work to login. You need to manually put in your email and password with the check mark next to your email & password.
08-08-2023 08:40 AM
@AshMc Sorry, the 2FA cannot be skipped even Face ID was used. But remember to check mark the "Trusted device" option at the bottom and in many cases the system won't send you another 2FA code
08-08-2023 08:36 AM
Are you using Public mobile app or web browser?
Public mobile introduced the eversafe Login just recently. Unfortunately, there are still things that PM needs to improve. PM team is still working on fixes to improve the experience.
I do find that if I am at home on Wifi, when I access my account , use the same device (PC) and enter my password, I do not need to do 2FA authorization. Using the Public mobile app, outside the home for my account, also does not need 2FA.
08-08-2023 08:22 AM - edited 08-08-2023 08:25 AM
@AshMc Sorry there no way to turn off 2FA . Code will be randomly sent at times
Add if you click trusted device on safari or google and have code sent it should sign you back in again with out needing the code
