03-24-2022 03:56 PM
I got the email about the Public Points Jackpot and I don't know how to opt into rewards, Every time I go onto rewards I get an error. I don't know how to fix this error. Someone please help me.
03-24-2022 05:08 PM
do you open Browser from computer
and check also Browser update
03-24-2022 05:01 PM
@Nab_S if you have never been able to login, that is a different issue. I suggest you to open a ticket with PM and have them to look into it. Make sure they know it was from very beginning and nothing to do with this afternoon system issue
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
03-24-2022 04:49 PM
Very sad that they haven't fixed this yet. I've been getting this error since the new points system was released.
03-24-2022 04:38 PM
Yes, that error caused when the system got confused for the old rewards members. It was trying to show the Points system on old rewards members and hence Ooops 🙂
03-24-2022 04:26 PM
@softech just said he is having issues as well. It may be for people who are currently under the old rewards I am sure it will be resolved in a timely fashion
03-24-2022 04:25 PM
@Nab_S Maybe try rebooting your devices before another attempt.
03-24-2022 04:24 PM
Good to hear the new points rewards have one (tiny) advantage.. 😊
03-24-2022 04:23 PM
So maybe something is wrong with my account.. since everyone's is working? I have no idea what to try anymore, I've tried signing in on 3 different devices. Nothing works.
03-24-2022 04:18 PM
lol I just tried to sign in and it worked exquisitely. It brought right into my points/reward page without even that error screen where I have to click return.
So it looks like there is one thing that the new program is superior at compared to the old program....and probably literally the only thing
03-24-2022 04:18 PM
I have been getting the error since the new points system was added.
03-24-2022 04:18 PM
It's been like this since they've added the new points system, same error, I've been waiting for them to fix this but it doesn't seem to be getting fixed.
03-24-2022 04:17 PM
@Nab_S PM often has website glitches, so just wait an hour before retrying. Always a good idea to clear your browser cache/cookies before logging into your accounts though.
03-24-2022 04:16 PM
@Nab_S No worry, you didn't get migrated into the Point system.
I cannot see my old reward and I got the same Oops screen. I guess it is a system issue. So, sit back and try again later tonight
03-24-2022 04:15 PM
Pressing return reloads the page and the same error pops up on the screen.
03-24-2022 04:13 PM
I just tried both, neither worked
03-24-2022 04:09 PM
At least every time I have got that error screen, one extra click on return seems to get me past it with no issue.
03-24-2022 04:08 PM
I think it is just a glitch currently. If you just click on Return it should bring you the rewards page and be in good working order. Hopefully they fix that little hiccup soon.
03-24-2022 04:07 PM
try to do clear cache and cookies and use inPrivate mode.
03-24-2022 04:07 PM
Just tried it on edge and my phone, both have the same error message.
03-24-2022 04:04 PM
@Nab_S I think no worry. The screen you got, I got it sometimes. It likely because the system opened the wrong page (Points instead of old rewards) and hence it said something wrong
So, you just need to clear cache and restart your browser, or try on another browser (Edge/Firefox/Chrome) or use Incognito mode , or use another computer and test
03-24-2022 04:03 PM
I don't see an option to opt it, as soon as I log in, all I see is this no matter what I click.
03-24-2022 04:02 PM - edited 03-24-2022 04:05 PM
@Nab_S If you activated Jan. 25th/2022 or after, then you need to log into the Rewards page using the same email/password as for your self serve account and you will see the option to enter for the contest. Here's the link to the Rewards login: https://www.publicmobile.ca/myrewards
edit: @Nab_S Reminder that if you opt into the new points system you'll lose the $2/30 days autopay discount and will instead get 5% off all payments and purchasing add-ons. And there's no option to return to the old rewards.
03-24-2022 04:00 PM
I joined on Wednesday December 15th, 2021.
03-24-2022 03:59 PM
I can't find the option to opt in though.
03-24-2022 03:59 PM
@Nab_S To enter the contest you need to be on the new points rewards system and it's strongly advised for longer term customers to not switch to the new points system as the old rewards offer much better value and once you switch, you'll not be able to go back to the old rewards.
When you did you activate?
Here's a thread about the new points: https://productioncommunity.publicmobile.ca/t5/Announcements/Introducing-Public-Points-Rewards/td-p/...
03-24-2022 03:57 PM
That's an irreversible choice. People here would say don't do it.
