3 hours ago
Do the US travel plans cover Alaska? We purchased one last year and we didn't have any cell service. We were on a cruise and in cities with ports of call
2 hours ago
Thank you that's very helpful
3 hours ago
Depending on your phone, go into network settings, turn off automatic and then a list of providers will show. Pick ATT and make sure data roaming is turned on. Then reboot the phone.
3 hours ago - last edited 3 hours ago
hi @Judyw9991 no need for Airalo as PM's roaming works in Alaska
Automatic should pick up the AT&T signal, if not, just got to Settings , Mobile network and manually choose AT&T
3 hours ago
@softech wrote:problem with Alaska before has nothing to do with 3G. It was just PM's lost the roaming partnership with AT&T during that time.
With AT&T's partnership back now, people has been using roaming in Alaska in most major city areas there without problem
It looks like I was reading an older cached version.
Hey @Judyw9991 - https://www.publicmobile.ca/en/qc/get-help/articles/roaming-add-ons
(roaming now works on most cities, if not all, you mentioned above)
Add: recent confirmation
https://productioncommunity.publicmobile.ca/t5/Get-Support/Greetings/m-p/1214852
3 hours ago
How do you connect with AT&T
3 hours ago
Thank you
3 hours ago
hi @Judyw9991 Yes, Alaska is now covered
Last year, PM roaming does not work with AT&T but it is working now. So, make sure you connect to AT&T and set it to 4G or LTE
https://www.publicmobile.ca/en/qc/get-help/articles/us-roaming-troubleshooting
EDIT: I clicked on an older cached version of roaming in Alaska.
