02-25-2023 10:24 AM
How do I transfer a number from a lost phone? It's been over 2 hours since I tried the activation but it hasn't worked yet. Tried creating the ticket but the ticket requires the last payment but I haven't had to pay yet.
02-25-2023 11:24 AM
@dust2dust True , I fumbled that reply … only thing I’m certain of in my responses to OP was how to submit a ticket … the rest is a lil foggy as to what OP truly trying to do … hope they give us a reply .. and again sorry if I caused unnecessary head scratching @Tammyg0505
02-25-2023 11:11 AM
@Handy1- It's the problem with jumping in with the fast reply. I actually interpret the OP the same way with all the specific keywords they used. So we'll see what they might come back with.
The first part suggests sim swap. The second actually says activation. The third part says they haven't paid which suggests activation. But could also suggest before renewal.
02-25-2023 10:51 AM
@Tammyg0505 I’m sorry if I just added confusion to the mix ,, I wasn’t completely sure of your request … and should have just simply asked if you were trying to port a number or sim swap which @softech @has given you excellent step by step instructions on how to
02-25-2023 10:51 AM
You need new SIM and to be able to log in to your PM account.
Then go to
02-25-2023 10:34 AM - edited 02-25-2023 10:36 AM
you are an existing customer and you lost you phone and got a new sim card?
if so, you do NOT activate the sim using the activation portal.
Instead, , login to My Account from ONLY a desktop or laptop computer to request Change Sim card (please note that due to some glitches, accessing change sim care from mobile phone or tablet won't work)
After you logged in, unsuspend first if you have suspended your service earlier.
Then click Quick Links on the top right and select Change Sim card and follow the steps:
https://selfserve.publicmobile.ca/en/account/edit/your-account
02-25-2023 10:32 AM
02-25-2023 10:29 AM
@Tammyg0505 But if you need to submit a ticket to support here’s the links
Watch for reply top of page to the
Right ( envelope image )
02-25-2023 10:29 AM
@Tammyg0505 additional info on porting
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
02-25-2023 10:27 AM
@Tammyg0505 You need the number you’re porting to PM to be active ? Maybe contact old provider to get a new SIM card with number on it and then port to PM unless your old provider happens to be Telus or Koodo , in that case it’s possible the Telus porting team can fix it on there own
