08-04-2023 05:27 PM
4 days ago I transferred my Fido number to Public Mobile and the number is working completely fine (I can send/receive SMS and calls) but when I go into my iPhone's cellular settings and look at the eSIM it still shows the old (temporary Public Mobile) number. Under Phone settings I look at My Number and it is also the old (temporary) number. iMessage also says that my number (the number I'm currently using, not the temporary one) will expire in 25 days. I've restarted the phone multiple times, there are no iOS updates and no carrier settings available. Is there generally a lag before this updates?
08-04-2023 05:45 PM
@kd7iwp all good now? glad it helps!!
08-04-2023 05:42 PM
@softech Great suggestion. I reset networks and upon restart the number is now correct.
08-04-2023 05:39 PM
@kd7iwp try to click Reset All Networks and make the change once more after (please note it will also delete your saved it Wi-Fi and Bluetooth connections, you just have to manually add them back after)
If still fails, you might want to check with Apple Support as it is more an Apple iOS issue
08-04-2023 05:36 PM
@softech I have done that countless times already and the change is never saved. Yes, I can send/receive calls and sms on the number. Service is functioning correctly, it's just that in the settings on my iPhone 14 Pro anywhere that my number is listed it has the old Public Mobile number.
08-04-2023 05:35 PM
@kd7iwp important question, you can receive calls??
try this:
Here's what you need to do:
Open Settings. Go to ‘Phone’ and then ‘My number’. Then manually change the number in this field.
Turn your phone on and off again to reboot the settings.
08-04-2023 05:35 PM
@Handy1 , no the old Fido sim no longer works, as expected.
08-04-2023 05:34 PM
@kd7iwp And does your old Fido SIM card still work ?. If so the port is not complete . But you can message support to refresh your account also
private message To CS_Agents click
VVVVV Link below VVVVV
08-04-2023 05:31 PM - edited 08-04-2023 05:33 PM
@Handy1 Yes I did, that is why the number is working fine on Public Mobile. My only problem is that the old Public Mobile (temporary) number still shows up in my settings. I am correctly receiving/sending calls from my old Fido number through Public Mobile and it took less than an hour on Monday for that transfer process to work.
08-04-2023 05:30 PM
@kd7iwp Did your reply yes to your old providers text a message confirming the port by replying YES . Or miss the text completely. There a number for live support that can give status update on the port or re trigger it if needed . Will send you private message . As we not allowed to post it here
