02-24-2023
09:54 PM
02-24-2023
11:01 PM
computergeek541
Hello, i didn't respond to the text message that my old provider sent me and it's expired. Is there a way you guys can request another time?
02-24-2023 11:27 PM
For those like me who are less Tekke
I could suggest the analogy ….
That my car my Old House Key(s)
don't work in the New Place I move to
This issue seems to keep coming up
I suggest that PubMo slightly better concept Langauge
in the Transfer instructions
Porting can be a confusing term
Think
Dongle the first thought for peoples of a certain age is not
Adapter
Likewise for USB Hub could be better understood
for many as a USB Splitter
As for the original post Veradawli
I am almost 100% sure PubMo
will get it sorted asap
If not please post again
you already have 2 Smart People Helping
Plus my own encouragement to hang in there
I transferred to PubMo 2 Months ago
I think its Awesome and I couldnt be Happier
02-24-2023 09:57 PM
Sounds like a stuck in port issue .
Will send you porting team number
For live support to fix the issue
Private message . Top of page envelope icon
Additional info on porting
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
02-24-2023 09:55 PM
@Veradawli no worry
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
