12-05-2025 06:42 PM
I recently transferred my Rogers number to Public Mobile. But my internet isn't working. How can I fix it? I'm using an iPhone at the moment.
12-05-2025 06:53 PM
I am able to make and receive calls, but I do not have access to RCS, iMessages, or internet connectivity.
12-05-2025 06:47 PM
hi @Rj1313
make sure you removed Rogers sim card, disable Rogers eSIM
then update Carrier Profile
Last, reboot phone and Reset Network Settings
12-05-2025 06:46 PM - edited 12-05-2025 06:47 PM
Hello @Rj1313
It sounds like the Rogers network settings info is still there. Try resetting them.
To reset your iPhone's network settings, go to Settings > General > Transfer or Reset iPhone > Reset, and then select Reset Network Settings. Then restart your phone.
Is it just the data stream that's the issue? You can make and take calls, iMessages work too?
