55m ago
- last edited
38m ago
Having the same issue here. Currently in Seattle, roaming turned on, connected to the AT&T successfully. The 5G logo is on but still no Internet connection.
It just happened recently. There was no such thing before
40 seconds ago
if the previous suggestion fails...try rebooting your cell. Sometimes that helps to get things right again.
39m ago - last edited 38m ago
It could be a problem with roaming on AT&T.
But first, make sure you have turned on Roaming Data on in the phone
Next, change the Network Connection from Automatic to Manual and select and test each of these networks: T-Mobile/AT&T/Verizon, and see which one you can connect and work best
If you able to connect to one of these and work, please report back and let us know which working network is that
