06-02-2023 08:57 PM
I setup esim on the wrong device when setting up PM. How do I change esim to the other iphone? Going through the Apple menu gives an error to contact PM.
06-02-2023 09:03 PM
Thank you
06-02-2023 09:02 PM
@GregA Yes in your my account
SIM SWAPPING profile tabs
06-02-2023 09:01 PM
Can I change from esim to physical sim?
06-02-2023 08:59 PM - edited 06-02-2023 09:00 PM
@GregA You can only activate on esim at the moment no way to transfer it to another device
you can confirm with support
Add your best option would be to get physical SIM card
