12-04-2024
05:00 PM
12-04-2024
06:06 PM
computergeek541
Unfortunately my phone setup was started with an ESIM but then I found out that my phone was incompatible, and now I'm stuck. I now have a physical SIM card but am unable to enter the details as the activation has already been started another way. I need an account reset but I can't seem to submit a ticket or get anyone in the chat to reset my account. Is there a way to bypass this?
12-04-2024 05:22 PM
To add, the wait times for CSA help are longer than usual. Usually 1-2 hour response times. Now up to 1-2 days response times. Hopefully, it is getting better now after Black Friday and Cyber Monday.
Check your private message inbox for response.
12-04-2024 05:02 PM
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
