06-02-2023
07:28 PM
06-02-2023
08:48 PM
computergeek541
@CS_AgentIm trying to transfer my existing number over from Koodo prepaid but I was told to submit a ticket first. Please help as my legs are getting tired. Thank you
06-02-2023 08:47 PM
@Yvonne58 wrote:Lol thanks everyone I’ve sent a PM already and I’m currently sitting down! Thank you!
self solution removed
06-02-2023 07:45 PM
The reason for this is because Koodo prepaid shares the same systems as Public Mobile as they are both under the TELUS umbrella.
Public Mobile has to simply manually switch the carrier in their system from Koodo to Public Mobile.
You should be good to go within an hour or so...
06-02-2023 07:42 PM
06-02-2023 07:41 PM
06-02-2023 07:29 PM
@Yvonne58 is your current PM line working, can make outgoing and receive incoming calls?
If so, simple open a ticket with PM support by direct message:
06-02-2023 07:29 PM - edited 06-02-2023 07:30 PM
