Transfer a Phone number from Telus to Public Mobile
EmilyB
Hi,
I'm trying to transfer my phone number from Telus to Public Mobile. I missed replying YES in the first 90 minutes. How do I get another activation meassage sent out? I see that Public Mobile has given me a number but it is not the same as the one I had before. Is there a number I can call to resolve this?
@EmilyB  OR, you can submit a ticket with Public Mobile representatives (CSA) to get them to resend the request to Telus; click this link to do so for issues with transfer/porting of phone numbers over to Public Mobile.
@hTideGnow @Handy1 @softech - all within the same minute! 😆
HI @EmilyB  will message you the number.  Please check
@EmilyB  You can call Telus porting team to restart port or possible do it with a verbally will send you the number private message
@EmilyB
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
