08-14-2022 04:02 PM
We have unlimited text and calling. However, texts aren’t sending unless on wifi
08-15-2022 12:05 AM
@BakerE - yes your son should have unlimited texting.
iMessage can use data, and you are out of data for your current cycle be sure to have SMS and MMS enabled in the settings of your son's device.
08-14-2022 04:44 PM
@BakerE wrote:My son has used up all of his data. However, our plan is unlimited texts so shouldn’t he still be able to receive texts?
To send/receive PLAIN SMS you need mobile phone Plan and NOTHING else. And use native texting app which came with your phone, OS.
Do NOT use proprietary apps (like apple and other crap) and SMS will work like a charm.
If you are sending/receiving pictures which is considered MMS then you have to have DATA set to On. It will NOT use your data allowance but it has to be enabled EVEN though you do not have data available.
Native SMS has nothing to do with WiFi.
08-14-2022 04:39 PM
@BakerE wrote:How do you do that?
Do NOT solution your own answer!
08-14-2022 04:31 PM
08-14-2022 04:27 PM
are you use text SMS or MMS..?
text SMS no need data on
MMS need turn data mobile on to you receive it or sending.
08-14-2022 04:24 PM
08-14-2022 04:12 PM
Yeah I think some phones cannot receive messages unless data mode is turned on, even if its not imessage, I believe once you keep your data mode on, you should be able to receive texts.
08-14-2022 04:11 PM
08-14-2022 04:10 PM
08-14-2022 04:06 PM
If I turn off iMessage I’m able to send texts but not receive them.
08-14-2022 04:04 PM
How do you do that?
08-14-2022 04:04 PM
What kind of phone do you have? What app do you use for SMS?
SMS has nothing to do with WiFi unless it is some kind of 3rd party SMS app.
Native SMS app works with regular cellular network and only thing you have to have is active Plan.
08-14-2022 04:03 PM
if you use MMS you need to turn data mobile on.
