08-14-2022
11:07 PM
08-14-2022
11:28 PM
computergeek541
Hi, I'm traveling out to BC from Ontario and I am a little unclear about how the traveling will impact my phone coverage. Do I have to get an add-on for the time I'm traveling to be able to send and receive emails, texts and calls from Ontario while I am in BC? I have a plan that allows me to call anywhere in candid for free anywhere but the wording on the add-ons page seems to suggest I need to buy more for my phone to work as expected. Or do I just keep on trucking and not worry about anything while traveling? I'd appreciate any help in understanding it. Thanks!
08-15-2022 01:44 AM
PM plans are across Canada so you can call or text where there are Telus and Bell towers near by.
The only time you need Roaming is when you are in the USA.
08-14-2022 11:21 PM - edited 08-14-2022 11:22 PM
no need any add-ons.
if your plan has Canada-wide minutes/SMS/MMS.
you can use anywhere in Canada. and no additional fees.
08-14-2022 11:11 PM
Just keep on trucking and not worry about anything while traveling. All of the services will work the same all across Canada while connected to the Telus/Bell network. Except what we know of Brandon and Winnipeg
