Switching from 3G plan to 4G with old rewards program
Nojunkmail99bh
Is it possible to switch from a 3G plan with the old rewards program to a new 4G plan and stay in the old rewards program?
Thanks
self solution removed, solution re-assigned
Nojunkmail99bh
That’s great news and advice. Many Thanks!
hairbag1
Yes ...you stay on Rewards UNLESS you opt out...so don't opt out of Rewards.
Nojunkmail99bh
Great advice - thanks so much for your help
dabr
@Nojunkmail99bh   Yes, the rewards are attached to your account and do not get affected by plan changes.  You might want to schedule the plan change for next renewal as rewards don't get applied for immediate change and PM doesn't prorate or refund for unused days left in your current cycle.
