New rewards program
JauneSale
Hi Guys,
I'm kind of late, but I just realized that the new rewards program is very bad.
Is there a way to get back the fidelity program?
Thanks!
eddieO
@JauneSale, it doesn't look like it's been mentioned here and just in case you were not aware, with the new points system you will need to manually redeem 15 points to get a $15 bill credit, or you can choose to use your points towards Add-ons like more data, long distance minutes etc.
RavingRaven
@JauneSale
Hahaha.....no. We wished, we prayed but no go....alas at least you didn't screw up like I did and move the wife and myself to join the points program based on an erroneous email sent at the program's debut back in 2022.
hi @JauneSale you just found out now? the announcement was back in March and everyone got moved in May
No one can stay with the legacy system. So, 5% point is what you getting.  But the Friend referrals is still here, easy 1 point per cycle
and of course the "easy but not so easy" Comminity points
slusagm
sorry, no way to get back.  The old system is gont and there is only one rewards system now, Public Points
