a month ago
I messed up with my phone trying to get into may account, Now i need to print my bills still locked out
a month ago
check this, maybe helpful to unblock it
https://www.zdnet.com/article/what-to-do-when-chrome-stops-letting-you-download-pdfs/
or try using PM app to download
But , you can also ask PM to send you the bills to your email, just explain you can't download for whatever reason
a month ago
hi @Leinad the block is a device setting. Try with another phone or try with another computer
a month ago
yes this let me in thanks so much however it wouldnt let me down load my bills it blocked the pdfs
a month ago
with Chrome in phone, click on the 3 dots on top right and select New Incognito tab ...
a month ago
crome
a month ago
What browser are you using? Chrome? Firefox? Safari....?
a month ago
hi @Leinad usually clock on the 3 dots or 3 lines on top right of the browser to bring up the menu. It could be called Incognito or Private or secret mode depending on the brand of the browser
if you can't find it to test, just message support agent for help using the link above
a month ago
not sure how to, use Incognito/private/secret mode
a month ago
Read this thread as this solution may work for you for your lock out issue. Otherwise as suggested contacting customer support can get you receipts for your payments if you cannot login in the near future.
*Note the other user in the thread that details how it worked for them as well.🤞
https://productioncommunity.publicmobile.ca/t5/Get-Support/Re-Troubleshooting-Login-Issues-OTP-2FA-E...
a month ago
You can message Public Mobile directly for assistance to unlock your account. They will reply via same.
a month ago
hi @Leinad
try again in an hour using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then please submit a ticket with CS Agent by direct message:
