Saturday - last edited Saturday by computergeek541
Hi @CS_Agent
I am not seeing above option in my subscription plan to change as a boxing week special.
wha do I need? The plan is for $35 for month for Canada, USA and Mexico with5G speed, 75 GB per month unlimited call and unlimited international texting.
please let me know.
thank you
Saturday
Existing customers can absolutely get it, but it won't show as an available option if your current plan is $36 or more. If that's the case the workaround is to downgrade to the $30 plan now, and then you'll unlock the $35 option that you can change into at next renewal (as @ORNGNBLK mentioned).
Saturday
@TheSterlinger wrote:@Mahendiran this plan is for new activation only. As existing members if you want that plan you'd have to port out and port back in as a new customer.
The $35 75GB isn't for new activations only. Some existing customers can get it.
Saturday
Saturday
@Mahendiran if you see a $30 plan, you can change to that immediately and then change to the $35 plan, but change to that one on renewal. You will lose any unused minutes and data on your current plan. But it may be worth it for you. PM has made it difficult to downgrade from more expensive plans but this workaround works.
Saturday
@Mahendiran wrote:I am not seeing above option in my subscription plan to change as a boxing week special.
what do I need? The plan is for $35 for month for Canada, USA and Mexico with5G speed, 75 GB per month unlimited call and unlimited international texting.
Unfortunately, this means that the plan isn't available. This plan is only available to either new customers and some existing customers.
