01-05-2025 10:13 PM
I currently have the $35 50GB plan.
50GB Data within Canada, the US and Mexico at 5G Speed
I see two $35 plans on the site as attached -two questions
a) Do all plans come with call forwarding, conferencing even if not listed?
b) It seems like the 75GB and 1000min plan is an obvious better choice - what am I missing?
01-05-2025 11:21 PM
No brainer. Do it. You won't lose any of those features.
01-05-2025 10:21 PM - edited 01-05-2025 10:25 PM
...@nhsadika2 hi, yes the 75GB is a better plan. All of Public Mobile's plans comes with voicemail, call forwarding, display etc, it's stated on the next page when you click it. I believe the difference is that the 75GB has 1000 minutes as opposed to the other at 500 minutes.
If you need it, go for it. Change on Renewal yes ✋
They both say for new activations only. ..
