04-09-2025
11:25 AM
04-09-2025
04:35 PM
computergeek541
I subscribed for esim package,but my phone isn't compatible with esim. I want to move subscription to physical sim that I have purchased.
04-09-2025 04:36 PM
@funpig1 wrote:Open the App. Tap Account and select Change your SIM card.
As the customer's service has never worked, the customer will not be able to get into the Self Serve account to do this.
04-09-2025 11:38 AM
hi @Alihabeeb
at this stage, you won't be able to make the change yourself, you need PM support to help
you can submit ticket by direct message:
04-09-2025 11:35 AM
@Alihabeeb I think if you are in the process of activating a new account with Public Mobile and had opted for esim initially, you will need to contact customer service to change to physical sim. You can send them a private message using this link
04-09-2025 11:30 AM
Go to Profile where you can do:
- Change phone number
- Change SIM number
- Transfer Phone Number
04-09-2025 11:30 AM
