Support
RS12
  • Is it impossible to get non robotic customer service with public mobile?
9 REPLIES 9
were you using the message link here?
Try again, or if still showing error, post us a screenshot.
bertfyoung
OK I tried tto open a ticket and there is an error submiting saying I need to fill all areas which I did ! tried a couple of times and the error persists.
@bertfyoung wrote:
I have tried this route many times the last few days ..it sends you in a loop back to login public mobile and public mobile community , etc. this a very discouraging method of support?
@bertfyoung
use the message link I provided above and you will be able to to get to them
bertfyoung
hairbag1
@RS12
let us know what the problem is and we can usually help resolve it or at least provide direction to correct resource.
Yummy
Yes, it is.
You have to open a ticket through chatbot (type 'ticket' and follow prompts until you get a link to a ticket).
Support will be through Community mail; you will not be able to talk any other way to PM support 'live' person.
@RS12
There are several ways to contact a CS_Agent as noted by others but you can also dm them by clicking on your avatar then on Messages and address it to CS_Agent.
slusagm
if your have an account related question, a PM live support staff will help.  Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
hi @RS12
of course you can.  While PM does not have a line to call,you can still submit ticket and a live person will reply in message
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
But of course, you can share your questions here and the Community will try to help as welll
