03-03-2024 05:41 PM
I'm running in circles with this and really need some help.
Got to step 4 on the website. Finish setup, Payment complete. It says sim is on the way, even though I already have one. But in the billing screen - it did not bill me for one.
Downloaded the app. Followed the instructions. Used my Koodoo IMEI instead of account. Got to step 6 and it shows subscription not activated.
Called the 1-800 number provided in private messaging. They were no help without an account number. Can't get my account number, when I click on my account from the website it takes me to "let's complete your activation".
Stuck in a circle of dead ends.... need help please.
3 hours ago
I am having the same issue....getting an error reading "subscription not activated - something didn't go right while activating your subscription. Click below to contact a customer service agent.' I have dome everything asked of me and it's been 18 hours and still not activation text from Koodo (my current provider).
03-03-2024 08:21 PM
Had to submit a ticket to reset my PM account to restart to the activation process as recommended by Telus helpdesk. No reply yet so we will see.
03-03-2024 08:00 PM
Did you get anywhere with this?
03-03-2024 05:47 PM
I can't find an account number, and any email which public has sent - everything is starred out besides the last 4 digits.
This should not be this difficult.
03-03-2024 05:45 PM
Same issue called porting number help team but they can't help with the subscription.
I have a ticket but it hasn't got me anywhere yet
03-03-2024 05:23 PM
03-03-2024 05:22 PM
Is mood sim the Koodo sim?
03-03-2024 05:08 PM
@AliG1 🤞
03-03-2024 05:07 PM
Thanks I have a ticket now. Pray for me
03-03-2024 04:49 PM - edited 03-03-2024 04:50 PM
@AliG1 I’m not sure you can just have to contact support or the porting team to re trigger the port request and give them just the account number leaving the mood sim in the phone to reply YES to the confirmation text to port
will send you the porting team number private message also
03-03-2024 04:47 PM
Me too
03-03-2024 04:47 PM
How can you go back and enter the Koodo account number if you already entered the imei number
03-03-2024 04:42 PM
Thanks, on hold with the customer service team right now.
03-03-2024 04:35 PM - edited 03-03-2024 04:37 PM
@Catzc It’s best to use Koodo account number and ignore the IMEI . But if this is Koodo pre paid you need to take a temp PM phone number then ask support to transfer Koodo number over for you . But if Koodo pre paid you should be able to do so on activation leaving the Koodo SIM card in phone to reply YES to the confirmation text . If you missed this text you can call the porting team to re trigger the request . Will send you that number private message if you end up needing it
03-03-2024 04:33 PM
HI @Catzc
yes, test it and see if it connects to PM network
but even it works, you need to put the Koodo sim back to the phone after to wait for the porting authorization text from PM
03-03-2024 04:31 PM
Thanks, have already done messaged CS.
@hTideGnow No, we have not installed the sim yet. Should we?
03-03-2024 04:30 PM
It looks as though Koodo to Public is an issue. I also used the IMEI, instead of Koodo account number. Locked in step 6 also.
03-03-2024 04:29 PM
@Catzc If chat bot is not working for you , try this direct link to support
send a private message To CS_Agents
03-03-2024 04:29 PM
HI @Catzc
and you tried the PM sim card in the phone and cannot connect?
You need to contact PM support agent and have them confirm if the account setup was done. Ask them to also confirm if porting was submitted properly
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-03-2024 04:25 PM
Also having this issue Koodo to Public. Stuck in the endless loop of Step 6 and chat bot questions. Physical sim, not esim. Seems as though Public has a recurring problem which they need to fix...
