Subscription Change not reflected on Public App
LM321
I changed my subscription to a new plan on Nov 24th. The Public mobile app is still showing my old plan. When I sign in on the Public site it shows the upgraded Subscription but not on the app.
LM321
Thanks tried that but no updated Subscription on the app
LM321
Thanks but it didn't work
LM321
Thanks   I still haven't seen the change on the app.
ToniL
its a glitch! that happened to me as well.  just wait a few days you will see it.  I remember i saw the change via the browser, but then i don't see it on the app (just like you).  But few days later i look at the app again, it changed.
hi @LM321
a quick way to do is to pull the screen down to force a refresh.
if same, then  logout first and log back in
hairbag1
@LM321
it's a longshot, but try rebooting your cell, then log in again.
