08-25-2023 02:14 PM
08-25-2023 02:43 PM
Finished with PM and the number
08-25-2023 02:33 PM
@JaneXia wrote:Hi there. I want to stop using this phone number, what should I do?
HI @JaneXia
you meant you don't want to use your account any more?
if you know the account pin, just dial *611 and disable Autopay. No more renewal at the end of your current cycle and the account will be closed after 90 days
or you can login to My Account, Payment, Manage Subscription and disable Subscribed
08-25-2023 02:32 PM
a bit more info please. Are you taking your number to different network or finished with PM and the number ?
08-25-2023 02:27 PM
If you want to change your existing phone number you can easily do this on your account page by selecting a new number. If on the other hand you no longer want to be with PM then just don't pay to renew your plan. Of-course if you have auto pay enabled then again just go to your account page and disable it. Hope this works for you.
08-25-2023 02:19 PM
@JaneXia you mean cancel your account? If so, log into My Account and remove Autopay turn off the subscription payments. OR, call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device) to remove Autopay.
90 days in non pay status your account closes.
08-25-2023 02:16 PM - edited 08-25-2023 02:19 PM
'Change Phone Number'
https://myaccount.publicmobile.ca/en/account/profile/update/phone-number
'Transfer Phone Number'
https://myaccount.publicmobile.ca/en/account/profile/transfer-phone-number
'Manage Subscription - Enable/Disable Auto-Pay'
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
