My phone has stopped stopped making and receiving calls. What do I do?
Chucke
9 REPLIES 9
Chucke
THANKYOU
Chucke
I TRIED  STILL NO ISSUE
All good. I do hope PM figures out what's causing this problem. Seems to be an issue for a lot of folks. Seen a lot of posts about it. I just can't figure why it's only affecting certain people. I'm just thankful my phone still works....
oh sorry @Chalupa_Batman , I misread and thought you said no reser Network . 🙂
@hTideGnow wrote:
hi @Chalupa_Batman
while it could be network issue, but I just helped a friend with Reset Network Settings.  So @Chucke , better try that first before you submit ticket with support as they will ask you to do that anyway
Not sure why you felt the need to reply to my comment. If you read it ....  @Fatima079 suggested resetting the phone. Resetting the network like what you suggested in your first post is one thing and a very common suggestion here for all of us that we make. But resetting the entire phone, not a suggestion anyone should be making here.
hi @Chalupa_Batman
@Fatima079 wrote:
Reset Network Settings and if that doesn't work, reset your phone
I would NOT suggest resetting your phone. That isn't the problem. It's Public Mobile. There are back end issues right now.
Fatima079
hi @Chucke
many had the problem since yesterday
please try reboot phone and Reset Network Settings
if same, ask PM support to check, you can  submit by direct message:
