Some MMS not downloading
Laura1999
This has been happening since December, and only viewable via WiFi. I have a Samsung S10e and all APN settings are updated per the suggestions in this community. It's frustrating!
Laura1999
I've done all of this now. As this issue is intermittent, it will take some time before I know if the fix worked. Thanks!
@Laura1999 if simply update does not work, there might be a bit more work then simply updating.  Many confirmed that you need to delete the current APN profile first.  Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces.  Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
         (or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Laura1999
Phone info in original question. I've already input these settings before posting.
@Laura1999
what phone do you have?? model and brand?? your phone might be affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Laura1999
This is when I'm receiving MMS. Data is on.
Meow
To send/receive MMS data has to be ON.
I did a short test and all 5 pics have been properly send/received.
