03-24-2024
11:35 AM
03-24-2024
10:36 PM
Dunkman
Hi,
My roaming data was working 2 days ago. Currently, when leaving our hotel, it does not connect to Verizon wireless. Only calls work. I restarted the phone, checked on/off ariplane and wifi mode.
I need to travel and use the GPS.
Kindly help us to solve it.
03-24-2024 02:52 PM
I have same problem with Verizon. just select provider manual, use T-Mobile or AT&T
03-24-2024 11:50 AM
@HumbertoSouza - Verizon isn't a roaming partner with Public Mobile. Manually connect to T-Mobile or AT&T.
Also if you switched to one of those two roaming partners and calls won't work use T-Mobile and set it to 2G / GSM / EDGE.
Also on AT&T use LTE (Not 5G) but T-Mobile is good with 5G.
03-24-2024 11:50 AM
Hi. If you are reading this message, this means the sugestion to change the carrier worked. I selected AT&T.
I will also be attentive to the auto network, 5G or LTE selection.
Thank you for your kick ans kind replies.
03-24-2024 11:49 AM
hi @HumbertoSouza turn off 5G from network mode, pick one with 4G
and manual connect to both T-Mobile and AT&T
03-24-2024 11:45 AM
@HumbertoSouza wrote:Roaming data is checked
Good...as per suggestion above...use T-Mobile or AT&T...not verizon.
03-24-2024 11:44 AM
03-24-2024 11:38 AM - edited 03-24-2024 11:40 AM
make certain that Roaming Data us enabled in settings.
added..use motel wifi to load your maps for your trip.
03-24-2024 11:38 AM
Public mobile's US carrier partners are T mobile or AT&T (not Verizon). Try to manually select one of the US partners.
Also, instead of 5G network or auto, manually select LTE.
