Us roaming not working
Hedard
I redeemed reward points for data in the US and it didn't work so I paid $30 for a non-US plan and it still doesn't work please help me
@Hedard wrote:
Oups i got a problem .. I have 2 phones with public mobile ..I went on vacation to the United States with only mine and not my wife's. I used my rewards in exchange for US roaming and since it didn't work I bought a $30 plan. I can't use it because I don't have the right phone.. is it possible to get a refund for 1 of the 2 or both since I didn't use anything at all?
You're going to have to reach out to a CS Agent and chat with them about what happened.
Please use the chatbot to open a ticket: https://widget.telus.tiia.ai/publicmobile/publicmobile.html?lang=en
If you receive an error message that you are unable to open a ticket, send a private message to a CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
Hedard
Hedard
Omg, just I just realized my problem..I have 2 phones on the same email. I went on vacation to the United States with only mine and not my wife's. I used my rewards in exchange for US roaming and since it didn't work I bought a $30 plan. I can't use it because I don't have the right phone.. is it possible to get a refund for 1 of the 2 or both since I didn't use anything at all?
@hTideGnow wrote:
hi @Hedard
so, you redeem for the US roaming Bundle? or US roaming data? Check My Account or My Rewards site to confirm you redeemed  the "roaming" add-on
Check if your phone has Roaming Data enabled, and make sure you connect to T-Mobile or AT&T or Verizon and try using 4G or LTE.
hi @Hedard
