02-01-2025 06:48 PM
I have a iphone SE 3rd generation. The spec. for the phone says it is 5G compactable. I switched from a 3G service to 4G , yet my phone indicates 3G service. I went to Settings - Cellular - Data Options - Voice & Data But the only options available are LTE or 3G . I'm paying for 4G plan and the phone is capable of 5G so why am I not able to receive the 4G signal?
Service
02-02-2025 07:53 PM
Thanks I'll try running of LTE
02-02-2025 07:48 PM - edited 02-02-2025 07:50 PM
hi @ooohnoo
first, LTE = 4G. With LTE, you should have good speed , close to 100Mbps as you have 4G plan
but make sure your iOS is updated, and your Carrier Profile is also the latest one
02-02-2025 07:45 PM
The menu only shows LTE or 3G
02-02-2025 07:44 PM
Thanks I'll check out if my phone is 2nd or 3rd gen
02-01-2025 07:23 PM - edited 02-01-2025 07:27 PM
make sure you're up-to-date on software updates...looks like 18.3 is currently available. I also have iP SE 3rd gen...it has 5G, but for best functionality, I just set it to LTE. Battery lasts waaayy longer and very little difference in operation.
PS....could it be that you have an iP SE 2nd gen ? Double check on that as 2nd gen doesn't support 5G.
02-01-2025 06:55 PM
hi @ooohnoo
manually change the network mode to 5G On or 5G Auto
To change an iPhone to 5G, you can go to Settings > Cellular > Cellular Data Options and then select 5G On. You can also choose 5G Auto to automatically switch between 4G and 5G.
02-01-2025 06:54 PM
@ooohnoo wrote:I have a iphone SE 3rd generation. The spec. for the phone says it is 5G compactable. I switched from a 3G service to 4G , yet my phone indicates 3G service. I went to Settings - Cellular - Data Options - Voice & Data But the only options available are LTE or 3G . I'm paying for 4G plan and the phone is capable of 5G so why am I not able to receive the 4G signal?
Hey @ooohnoo Go into settings - General - (bottom of page) Transfer or Reset iPhone - Reset - Reset Network Settings and then reboot. This may clear the 3G problem and you should have LTE working correctly.
02-01-2025 06:50 PM
@ooohnoo Set the phone to LTE since in this context LTE = 4G.
