Re: New Canada-US-Mexico plans
The-Micc
Thanks for the comment.  Did you have to buy any add-ons to have things work in Mexico?
DeanaN
 once you are subscribed and the plan is in effect you just need to make sure you're roaming is turned on on your phone and your network mode can connect to LTE I've attached a copy of my settings that works perfectly
HI @The-Micc
if you scheduled the plan and it starts on the day your Mexico trip started, you are all good.
if you want to be 100% sure, then you can actually make an Change now request on the day before your trip.  You will loss one day from your current cycle, but I think that is ok
The-Micc
I changed my subscription to CND-US-MEX and it happens to come into effect my next renewal, which is the day I leave :).  Tell me, once that plan is active, should I be good to go in Mexico?
hi @The-Micc
sorry, there is no roaming add-on for Mexico.  You need to change to one of those Canada/US/Mexico plan if you need roaming service in Mex
